Resolution (Bits) | 16 |
Number of input channels | 4 |
Sample rate (Max) (kSPS) | 250 |
Interface type | Byte-Wide, Parallel |
Architecture | SAR |
Input type | Pseudo-Differential, Single-Ended |
Multi-channel configuration | Multiplexed |
Rating | Catalog |
Reference mode | Ext |
Input range (Max) (V) | 2.5 |
Input range (Min) (V) | -2.5 |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 208 |
Analog voltage AVDD (Min) (V) | -5.25 |
SNR (dB) | 86 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 4 |
Digital supply (Min) (V) | 2.7 |
Digital supply (Max) (V) | 5.5 |
- True Bipolar Input
- Input Signal Range: ±2.5V
- 4-Channel Input Multiplexer
- Up to 250kSPS Sampling Rate
- Selectable 8-Bit or 16-Bit Parallel Interface
- 16-Bit Ensured No Missing Codes
- Offset: 1mV max
- Low Power: 200mW
- TQFP-48 Package
- Operating Temperature Range: –40°C to +85°C
- APPLICATIONS
- Data Acquisition
- Test and Measurement
- Industrial Process Control
- Medical Instruments
- Laboratory Equipment
The ADS8342 is a 4-channel, 16-bit analog-to-digital converter (ADC). It contains a 16-bit succesive approximation register (SAR), a capacitor-based ADC with an inherent sample-and-hold circuit, an interface for microprocessor use, and parallel 3-state output drivers. The ADS8342 is specified at a 250kHz sampling rate while dissipating only 200mW of power using a ±5V power supply.
The ADS8342 is available in a TQFP-48 package and is ensured over the ?40°C to +85°C temperature range.
