公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有 ADC、MUX、PGA 和内部基准的 14 位 48KSPS DAS
Resolution (Bits) 14
Number of input channels 8
Sample rate (Max) (kSPS) 48
Interface type SPI
Architecture SAR
Input type Differential, Single-Ended
Multi-channel configuration Multiplexed
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 5.5
Input range (Min) (V) 0
Features Oscillator, PGA
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 8.5
Analog voltage AVDD (Min) (V) 2.7
Analog voltage AVDD (Max) (V) 5.5
INL (Max) (+/-LSB) 4
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.5
  • PGA Gains: 1, 2, 4, 5, 8, 10, 16, 20 V/V
  • Programmable Input (Up to 4-Channel Differential/Up to 8-Channel Single-Ended or Some Combination)
  • 1.15-V, 2.048-V, or 2.5-V Internal Reference
  • SPI/DSP Compatible Serial Interface ( 20 MHz)
  • Throughput Rate: 48 kSamples/sec
  • Error Overload Indicator
  • Programmable Output 2s Complement/Binary
  • 2.7-V to 5.5-V Single Supply Operation
  • 4-Bit Digital I/O Via Serial Interface
  • Pin Compatible With ADS7870
  • SSOP-28 Package
  • APPLICATIONS
    • Portable Battery-Powered Systems
    • Low-Power Instrumentation
    • Low-Power Control Systems
    • Smart Sensor Applications
All trademarks are the property of their respective owners.
The ADS7871 (US patents 6140872, 6060874) is a complete low power data acquisition system on a single chip. It consists of a 4-channel differential/8-channel single-ended multiplexer, precision programmable gain amplifier, 14-bit successive approximation analog-to-digital (A/D) converter and a precision voltage reference.
The programmable-gain amplifier provides high input impedance, excellent gain accuracy, good common-mode rejection, and low noise.
For many low-level signals, no external amplification or impedance buffering is needed between the signal source and the A/D input.
The offset voltage of the PGA is auto zeroed. Gains of 1, 2, 4, 5, 8, 10, 16, and 20 V/V allow signals as low as 125 mV to produce full-scale digital outputs.
The ADS7871 contains an internal reference, which is trimmed for high initial accuracy and stability vs temperature. Drift is typically 10 ppm/°C. An external reference can be used in situations where multiple ADS7871s share a common reference.
The serial interface allows the use of SPI?, QSPI?, Microwire?, and 8051-family protocols, without glue logic.
