公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
18 位 500KSPS 并行 ADC
Resolution (Bits) 18
Number of input channels 1
Sample rate (Max) (kSPS) 500
Interface type SPI
Architecture SAR
Input type Pseudo-Differential, Single-Ended
Rating Catalog
Reference mode Ext
Input range (Max) (V) 4.2
Input range (Min) (V) 0
Features Oscillator
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 110
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 88
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 4
Digital supply (Min) (V) 2.95
Digital supply (Max) (V) 5.25
  • 500-kHz Sample Rate
  • 18-Bit NMC Ensured Over Temperature
  • Zero Latency
  • Low Power: 110 mW at 500 kHz
  • Unipolar Input Range
  • Onboard Reference Buffer
  • High-Speed Parallel Interface
  • Wide Digital Supply
  • 8-/16-/18-Bit Bus Transfer
  • 48-Pin TQFP Package
  • APPLICATIONS
    • Medical Instruments
    • Optical Networking
    • Transducer Interface
    • High Accuracy Data Acquisition Systems
    • Magnetometers
The ADS8383 is an 18-bit, 500 kHz A/D converter. The device includes a 18-bit capacitor-based SAR A/D converter with inherent sample and hold. The ADS8383 offers a full 18-bit interface, a 16-bit option where data is read using two read cycles or even an 8-bit bus using three read cycles.
The ADS8383 is available in a 48-lead TQFP package and is characterized over the industrial ?40°C to 85°C temperature range.
