公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
16 位 500 kSPS 双路 ADC,4 通道,串行输出
Resolution (Bits) 16
Number of input channels 4
Sample rate (Max) (kSPS) 500
Interface type SPI
Architecture SAR
Input type Differential
Multi-channel configuration Simultaneous Sampling
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 5.25
Input range (Min) (V) 0
Operating temperature range (C) -40 to 125
Power consumption (Typ) (mW) 150
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 83
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 8
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.5
  • 2 SIMULTANEOUS 16-BIT DACs
  • 4 FULLY DIFFERENTIAL INPUT CHANNELS
  • 2 μs THROUGHPUT PER CHANNEL
  • 4 μs TOTAL THROUGHPUT FOR FOUR CHANNELS
  • LOW POWER: 150mW
  • INTERNAL REFERENCE
  • FLEXIBLE SERIAL INTERFACE
  • 16-BIT UPGRADE TO THE 12-BIT ADS7861
  • PIN COMPATIBLE WITH THE ADS7861
  • OPERATING TEMPERATURE RANGE: -40°C to +125°C
  • APPLICATIONS
    • MOTOR CONTROL
    • MULTI-AXIS POSITIONING SYSTEMS
    • 3-PHASE POWER CONTROL
All trademarks are the property of their respective owners.
The ADS8361 is a dual, 16-bit, 500kSPS, Analog-to-Digital (A/D) converter with four fully differential input channels grouped into two pairs for high-speed, simultaneous signal acquisition. Inputs to the sample-and-hold amplifiers are fully differential and are maintained differentially to the input of the A/D converter. This provides excellent common-mode rejection of 80dB at 50kHz, which is important in high-noise environments.
The ADS8361 offers a high-speed, dual serial interface and control inputs to minimize software overhead. The output data for each channel is available as a 16-bit word. The ADS8361 is offered in SSOP-24 and QFN-32 (5x5) packages and is fully specified over the -40°C to +125°C operating range.
