公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
用于电机和电源控制的 6 通道、16 位、250kSPS、同步采样 SAR ADC
Resolution (Bits) 16
Number of input channels 6
Sample rate (Max) (kSPS) 250
Interface type Byte-Wide, Parallel
Architecture SAR
Input type Pseudo-Differential
Multi-channel configuration Simultaneous Sampling
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 2.6
Input range (Min) (V) 0
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 413.1
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 83.2
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 8
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.5
  • 6 INPUT CHANNELS
  • FULLY DIFFERENTIAL INPUTS
  • 6 INDEPENDENT 16-BIT ADC
  • 4 μs TOTAL THROUGHPUT PER CHANNEL
  • TESTED NO MISSING CODES TO 14 BITS
  • BUFFERED REFERENCE INPUTS
  • LOW POWER: 450mW
  • TQFP-64 PACKAGE
  • APPLICATIONS
    • MOTOR CONTROL
    • MULTI-AXIS POSITIONING SYSTEMS
    • 3-PHASE POWER CONTROL
All trademarks are the property of their respective owners.
The ADS8364 includes six, 16-bit, 250KHz ADCs (Analog to Digital Converters) with 6 fully differential input channels grouped into two pairs for high-speed simultaneous signal acquisition. Inputs to the sample-and-hold amplifiers are fully differential and are maintained differential to the input of the ADC. This provides excellent common-mode rejection of 80dB at 50KHz that is important in high-noise environments.
The ADS8364 offers a flexible high-speed parallel interface with a direct address mode, a cycle, and a FIFO mode. The output data for each channel is available as a 16-bit word.
