1 / 1
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  207粉丝
--- 产品详情 ---
14 位、62MSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) 62
Resolution (Bits) 14
Number of input channels 1
Interface type Parallel LVDS
Analog input BW (MHz) 300
Features High Performance
Rating Catalog
Input range (Vp-p) 2, 4
Power consumption (Typ) (mW) 1200
Architecture Pipeline
SNR (dB) 73
ENOB (Bits) 11.7
SFDR (dB) 85
Operating temperature range (C) -40 to 85
Input buffer No
  • HIGH DYNAMIC RANGE:
    ?????High SFDR: 85dB at 10MHz fIN
    ?????High SNR: 72dB at 10MHz fIN
  • ON-BOARD TRACK-AND-HOLD:
    ?????Differential Inputs
    ?????Selectable Full-Scale Input Range
  • FLEXIBLE CLOCKING:
    ?????Differential or Single-Ended
    ?????Accepts Sine or Square Wave Clocking Down to 0.5VPP
    ?????Variable Threshold Level
  • APPLICATIONS
    • COMMUNICATIONS RECEIVERS
    • TEST INSTRUMENTATION
    • CCD IMAGING
All trademarks are the property of their respective owners.
The ADS5422 is a high-dynamic range, 14-bit, 62MSPS, pipelined Analog-to-Digital Converter (ADC). It includes a high-bandwidth linear track-and-hold amplifier that gives good spurious performance up to the Nyquist rate. The clock input can accept a low-level differential sine wave or square wave signal down to 0.5VPP, further improving the Signal-to-Noise Ratio (SNR) performance.
The ADS5422 has a 4VPP differential input range (2VPP ? 2 inputs) for optimum Spurious-Free Dynamic Range (SFDR). The differential operation gives the lowest even-order harmonic components. A lower input voltage can also be selected using the internal references, further optimizing SFDR.
The ADS5422 is available in an LQFP-64 package.
