公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
用于模拟监控和控制的集成多通道 ADC 和 DAC
Number of ADC channels 8
ADC resolution (bits) 12
Number of DAC channels (#) 3
DAC: resolution (Bits) 12
Temperature sensing Remote
GPIOs 0
Interface type SPI
Features Temp Sensor
Operating temperature range (C) -40 to 85
Rating Catalog
ADC: sampling rate (KSPS) 100
ADC: analog input range (Min) (V) 0
ADC: analog input range (Max) (V) 5
DAC: settling time (uS) 3
DAC: output full scale (Min) (V) 0
DAC: output full scale (Max) (V) 2.5, 5.0
  • 100kHz SAMPLING RATE 12-BIT ADC
  • 8 ANALOG INPUT CHANNELS
  • THREE 12-BIT DACS
  • NINE OPERATIONAL AMPLIFIERS
  • THERMISTOR CURRENT SOURCE
  • INTERNAL 2.5V REFERENCE
  • SPI SERIAL INTERFACE
  • 3V LOGIC COMPATIBLE
  • SINGLE +5V SUPPLY
  • LOW POWER: 40mW
  • TQFP-48 PACKAGE
  • APPLICATIONS
    • CW LASER AND PUMP LASER CURRENT CONTROL IN DWDM
    • TEC COOLER CURRENT CONTROL IN DWDM
    • OPTICAL POWER MONITORING
    • TUNABLE LASER
SPI is a trademark of Motorola.
The AMC7820 is a complete analog monitoring and control circuit that includes an 8-channel, 12-bit Analog-to-Digital Converter (ADC), three 12-bit Digital-to-Analog Converters (DACs), nine operational amplifiers, a thermistor current source, an internal +2.5V reference, and an SPI? serial interface. External reference may be applied. Typical power dissipation is 40mW. For the ADC, the unbuffered analog input range is 0V to +5.0V, and the buffered analog common-mode input range is 0V to +3.8V. For the DACs, the analog output range is 0V to +2.5V or 0V to +5.0V.
The AMC7820 is ideal for multichannel applications where low power and small size are critical. The AMC7820 is available in a TQFP-48 package and is fully specified and tested over the ?40°C to +85°C temperature range.
