Resolution (Bits) | 16 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 500 |
Interface type | Byte-Wide, Parallel |
Architecture | SAR |
Input type | Differential, Pseudo-Differential, Single-Ended |
Rating | Catalog |
Reference mode | Ext, Int |
Input range (Max) (V) | 5.25 |
Input range (Min) (V) | 0 |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 85 |
Analog voltage AVDD (Min) (V) | 4.75 |
SNR (dB) | 83 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 4 |
Digital supply (Min) (V) | 4.75 |
Digital supply (Max) (V) | 5.25 |
- HIGH-SPEED PARALLEL INTERFACE
- 500kSPS SAMPLING RATE
- LOW POWER: 85mW at 500kSPS
- BIPOLAR INPUT RANGE
- TQFP-32 PACKAGE
- APPLICATIONS
- HIGH-SPEED DATA ACQUISITION
- OPTICAL POWER MONITORING
- MOTOR CONTROL
- ATE
The ADS8323 is a 16-bit, 500kSPS analog-to-digital converter (ADC) with an internal 2.5V reference. The device includes a 16-bit, capacitor-based successive approximation register (SAR) ADC with inherent sample-and-hold. The ADS8323 offers a full 16-bit interface, or an 8-bit option where data are read using two read cycles. The ADS8323 is available in a TQFP-32 package and is specified over the industrial –40°C to +85°C temperature range.
