Resolution (Bits) | 24 |
Number of input channels | 4 |
Sample rate (Max) (kSPS) | 20 |
Interface type | SPI |
Architecture | Delta-Sigma |
Input type | Differential |
Multi-channel configuration | Multiplexed |
Rating | Catalog |
Reference mode | Ext |
Input range (Max) (V) | 5.25 |
Input range (Min) (V) | 0 |
Features | 50/60 Hz Rejection |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 4.3 |
Analog voltage AVDD (Min) (V) | 4.75 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 252 |
Digital supply (Min) (V) | 1.8 |
Digital supply (Max) (V) | 3.6 |
- 24 BITS—NO MISSING CODES
- 19 BITS EFFECTIVE RESOLUTION UP TO 20kHz DATA RATE
- LOW NOISE: 1.8ppm
- FOUR DIFFERENTIAL INPUTS
- INL: 15ppm (max)
- EXTERNAL REFERENCE (0.5V to 5V)
- POWER-DOWN MODE
- SYNC MODE
- LOW POWER: 4mW at 20kHz
- SEPARATE DIGITAL SUPPLY 1.8V to 3.6V
- APPLICATIONS
- CARDIAC DIAGNOSTICS
- DIRECT THERMOCOUPLE INTERFACES
- BLOOD ANALYSIS
- INFRARED PYROMETERS
- LIQUID/GAS CHROMATOGRAPHY
- PRECISION PROCESS CONTROL
All trademarks are the property of their respective owners.
The ADS1254 is a precision, wide dynamic range, delta-sigma, Analog-to-Digital (A/D) converter with 24-bit resolution. The delta-sigma architecture is used for wide dynamic range and to ensure 24 bits of no missing codes performance. An effective resolution of 19 bits (1.8ppm of rms noise) is achieved for conversion rates up to 20kHz.
The ADS1254 is designed for high-resolution measurement applications in cardiac diagnostics, smart transmitters, industrial process control, weight scales, chromatography, and portable instrumentation. The converter includes a flexible, two-wire synchronous serial interface for low-cost isolation.
The ADS1254 is a multi-channel converter and is offered in an SSOP-20 package.
