公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有内部采样保持功能的 8 位、200MSPS、低功耗模数转换器 (ADC)
Sample rate (Max) (MSPS) 200
Resolution (Bits) 8
Number of input channels 1
Interface type Parallel CMOS, TTL
Analog input BW (MHz) 500
Features Low Power
Rating Catalog
Input range (Vp-p) 1.6
Power consumption (Typ) (mW) 210
Architecture Pipeline
SNR (dB) 47
ENOB (Bits) 7.5
SFDR (dB) 60
Operating temperature range (C) -40 to 85
Input buffer No
  • Single-Ended Input
  • Internal Sample-and-Hold Function
  • Low Voltage (Single +3V) Operation
  • Small Package
  • Power-Down Feature
Key Specifications
  • Resolution 8 Bits
  • Maximum sampling frequency 200 Msps (min)
  • DNL ±0.4 LSB (typ)
  • ENOB (fIN = 50 MHz) 7.3 bits (typ)
  • THD (fIN = 50 MHz) 61 dB (typ)
  • Power Consumption
    • Operating 1.05 mW/Msps (typ)
    • Power Down 1 mW (typ)
All trademarks are the property of their respective owners.
The ADC08200 is a low-power, 8-bit, monolithic analog-to-digital converter with an on-chip track-and-hold circuit. Optimized for low cost, low power, small size and ease of use, this product operates at conversion rates up to 230 Msps while consuming just 1.05 mW per MHz of clock frequency, or 210 mW at 200 Msps. Raising the PD pin puts the ADC08200 into a Power Down mode where it consumes about 1 mW.
The unique architecture achieves 7.3 Effective Bits with 50 MHz input frequency. The ADC08200 is resistant to latch-up and the outputs are short-circuit proof. The top and bottom of the ADC08200's reference ladder are available for connections, enabling a wide range of input possibilities. The digital outputs are TTL/CMOS compatible with a separate output power supply pin to support interfacing with 3V or 2.5V logic. The digital inputs (CLK and PD) are TTL/CMOS compatible. The output data format is straight binary.
The ADC08200 is offered in a 24-lead TSSOP package and, while specified over the industrial temperature range of ?40°C to +85°C, it will function over the to ?40°C to +105°C temperature range.
