1 / 2
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  212粉丝
--- 产品详情 ---
14 位、10MSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) 10
Resolution (Bits) 14
Number of input channels 1
Interface type Parallel CMOS, TTL
Analog input BW (MHz) 270
Features Low Power
Rating Catalog
Input range (Vp-p) 2, 4
Power consumption (Typ) (mW) 250
Architecture Pipeline
SNR (dB) 76
ENOB (Bits) 12.2
SFDR (dB) 85
Operating temperature range (C) -40 to 85
Input buffer Yes
  • SELF-CALIBRATING
  • HIGH SFDR: 85dB at NYQUIST
  • HIGH SNR: 76dB
  • LOW POWER: 250mW
  • DIFFERENTIAL OR SINGLE-ENDED INPUTS
  • +3V/+5V LOGIC I/O COMPATIBLE
  • FLEXIBLE INPUT RANGE
  • OVER-RANGE INDICATOR
  • INTERNAL OR EXTERNAL REFERENCE
  • APPLICATIONS
    • IF AND BASEBAND DIGITIZATION
    • CCD IMAGING SCANNERS
    • TEST INSTRUMENTATION
    • IR IMAGING
The ADS850 is a high dynamic range, 14-bit Analog-to-Digital Converter (ADC) that utilizes a fully differential input, allowing for either single-ended or differential input interface over varying input spans. This converter features digital error correction techniques ensuring 14-bit linearity and a calibration procedure that corrects for capacitor and gain mismatches. The ADS850 also includes a high-bandwidth track-and-hold that provides excellent spurious performance up to and beyond the Nyquist rate.
The ADS850 provides an internal reference that can be programmed for a 2Vp-p input range for the best spurious performance and ease of driving. Alternatively, the 4Vp-p input range can be used for the lowest input referred noise, offering superior signal-to-noise performance for imaging applications. There is also the capability to set the range between 2Vp-p and 4Vp-p, or to use an external reference. The ADS850 also provides an over-range indicator flag to indicate if the input has exceeded the full-scale input range of the converter.
The low distortion and high signal-to-noise performance provide the extra margin needed for communications, imaging, and test instrumentation applications. The ADS850 is available in a TQFP-48 package.
