公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
500kHz、12 位、6 通道同步采样模数转换器
Resolution (Bits) 12
Number of input channels 6
Sample rate (Max) (kSPS) 500
Interface type Byte-Wide, Parallel
Architecture SAR
Input type Differential
Multi-channel configuration Simultaneous Sampling
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 2.5
Input range (Min) (V) 0
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 50
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 71.1
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 2
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 6 Simultaneous Sampling Channels
  • Fully Differential Inputs
  • 2μs Total Throughput per Channel
  • No Missing Codes
  • Parallel Interface
  • 1MHz Effective Sampling Rate
  • Low Power: 50mW
  • 6X FIFO
  • APPLICATIONS
    • Motor Control
    • Multi-Axis Positioning Systems
    • 3-Phase Power Control
The ADS7864 is a dual 12-bit, 500kHz analog-to-digital (A/D) converter with 6 fully differential input channels grouped into three pairs for high speed simultaneous signal acquisition. Inputs to the sample-and-hold amplifiers are fully differential and are maintained differential to the input of the A/D converter. This provides excellent common-mode rejection of 80dB at 50kHz which is important in high noise environments.
The ADS7864 offers a parallel interface and control inputs to minimize software overhead. The output data for each channel is available as a 16-bit word (address and data). The ADS7864 is offered in a TQFP-48 package and is fully specified over the -40°C to +85°C operating range.
