公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
10 位、6MSPS 同步采样、四通道 ADC,包含并行 DSP/uP 接口和信道自动通道功能
Resolution (Bits) 10
Number of input channels 4
Sample rate (Max) (kSPS) 6000
Interface type Parallel
Architecture Pipeline
Input type Differential, Single-Ended
Multi-channel configuration Simultaneous Sampling
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 4
Input range (Min) (V) 1.4
Operating temperature range (C) -40 to 85, 0 to 70
Power consumption (Typ) (mW) 186
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 61
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 1
Digital supply (Min) (V) 3
Digital supply (Max) (V) 5.25
  • Simultaneous Sampling of 4 Single-Ended Signals or 2 Differential Signals or
    Combination of Both
  • Signal-to-Noise and Distortion Ratio: 59 dB at fI = 2 MHz
  • Differential Nonlinearity Error: ±1 LSB
  • Integral Nonlinearity Error: ±1 LSB
  • Auto-Scan Mode for 2, 3, or 4 Inputs
  • 3-V or 5-V Digital Interface Compatible
  • Low Power: 216 mW Max at 5 V
  • Power Down: 1 mW Max
  • 5-V Analog Single Supply Operation
  • Internal Voltage References . . . 50 PPM/°C
    and ±5% Accuracy
  • Glueless DSP Interface
  • Parallel μC/DSP Interface
  • APPLICATIONS
    • Radar Applications
    • Communications
    • Control Applications
    • High-Speed DSP Front-End
    • Automotive Applications
The THS1007 is a CMOS, low-power, 10-bit, 6 MSPS analog-to-digital converter (ADC). The speed, resolution, bandwidth, and single-supply operation are suited for applications in radar, imaging, high-speed acquisition, and communications. A multistage pipelined architecture with output error correction logic provides for no missing codes over the full operating temperature range. Internal control registers are used to program the ADC into the desired mode. The THS1007 consists of four analog inputs, which are sampled simultaneously. These inputs can be selected individually and configured to single-ended or differential inputs. Internal reference voltages for the ADC (1.5 V and 3.5 V) are provided. An external reference can also be chosen to suit the dc accuracy and temperature drift requirements of the application.
The THS1007C is characterized for operation from 0°C to 70°C, and the THS1007I is characterized for operation from ?40°C to 85°C.
