公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
双通道、DSP/uP 接口、信道自动扫描、低功耗、12 位、8MSPS ADC
Resolution (Bits) 12
Number of input channels 2
Sample rate (Max) (kSPS) 8000
Interface type Parallel
Architecture Pipeline
Input type Differential, Single-Ended
Multi-channel configuration Simultaneous Sampling
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 4
Input range (Min) (V) 1.4
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 188
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 69
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 1.5
Digital supply (Min) (V) 3
Digital supply (Max) (V) 5.25
  • Simultaneous Sampling of 2 Single-Ended Signals or 1 Differential Signal
  • Signal-to-Noise Ratio: 68 dB at fI = 2 MHz
  • Differential Nonlinearity Error: ±1 LSB
  • Integral Nonlinearity Error: ±1.5 LSB
  • Auto-Scan Mode for 2 Inputs
  • 3-V or 5-V Digital Interface Compatible
  • Low Power: 218 mW Max at 5 V
  • Power Down: 1 mW Max
  • 5-V Analog Single Supply Operation
  • Internal Voltage References ...50 PPM/°C and ±5% Accuracy
  • Glueless DSP Interface
  • Parallel μC/DSP Interface
  • APPLICATIONS
    • Radar Applications
    • Communications
    • Control Applications
    • High-Speed DSP Front-End
    • Automotive Applications
The THS1209 is a CMOS, low-power, 12-bit, 8 MSPS analog-to-digital converter (ADC). The speed, resolution, bandwidth, and single-supply operation are suited for applications in radar, imaging, high-speed acquisition, and communications. A multistage pipelined architecture with output error correction logic provides for no missing codes over the full operating temperature range. Internal control registers allow for programming the ADC into the desired mode. The THS1209 consists of two analog inputs, which are sampled simultaneously. These inputs can be selected individually and configured to single-ended or differential inputs. Internal reference voltages for the ADC (1.5 V and 3.5 V) are provided. An external reference can also be chosen to suit the dc accuracy and temperature drift requirements of the application.
The THS1209C is characterized for operation from 0°C to 70°C, and the THS1209I is characterized for operation from ?40°C to 85°C.
