公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
分辨率增强型 24 位、40kHz 模数转换器
Resolution (Bits) 24
Number of input channels 1
Sample rate (Max) (kSPS) 41
Interface type SPI
Architecture Delta-Sigma
Input type Differential
Rating Catalog
Reference mode Ext
Input range (Max) (V) 5.25
Input range (Min) (V) 0
Features 50/60 Hz Rejection
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 40
Analog voltage AVDD (Min) (V) 4.75
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 251.7
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 24 BITS—NO MISSING CODES
  • 19 BITS EFFECTIVE RESOLUTION UP TO 40kHz DATA RATE
  • LOW NOISE: 2.5ppm
  • DIFFERENTIAL INPUTS
  • INL: 0.0015% (max)
  • EXTERNAL REFERENCE (0.5V to 5V)
  • POWER-DOWN MODE
  • SYNC MODE
  • APPLICATIONS
    • CARDIAC DIAGNOSTICS
    • DIRECT THERMOCOUPLE INTERFACES
    • BLOOD ANALYSIS
    • INFRARED PYROMETERS
    • LIQUID/GAS CHROMATOGRAPHY
    • PRECISION PROCESS CONTROL
All trademarks are the property of their respective owners.
The ADS1252 is a precision, wide dynamic range, delta-sigma, Analog-to-Digital (A/D) converter with 24-bit resolution operating from a single +5V supply. The delta-sigma architecture is used for wide dynamic range and to ensure 24 bits of no missing code performance. An effective resolution of 19 bits (2.5ppm of rms noise) is achieved for conversion rates up to 40kHz.
The ADS1252 is designed for high-resolution measurement applications in cardiac diagnostics, smart transmitters, industrial process control, weight scales, chromatography, and portable instrumentation. The converter includes a flexible, 2-wire synchronous serial interface for low-cost isolation.
The ADS1252 is a single-channel converter and is offered in an SO-8 package.
