公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
12 位 4 通道并行输出采样模数转换器
Resolution (Bits) 12
Number of input channels 4
Sample rate (Max) (kSPS) 200
Interface type Parallel
Architecture SAR
Input type Single-Ended
Multi-channel configuration Multiplexed
Rating Catalog
Reference mode Ext
Input range (Max) (V) 5.25
Input range (Min) (V) 0
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 1.8
Analog voltage AVDD (Min) (V) 2.7
SNR (dB) 70
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 1
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.25
  • SINGLE SUPPLY: 2.7V to 5V
  • 4-CHANNEL INPUT MULTIPLEXER
  • UP TO 200kHz SAMPLING RATE
  • FULL 12-BIT PARALLEL INTERFACE
  • ±1LSB INL AND DNL
  • NO MISSING CODES
  • 72dB SINAD
  • LOW POWER:2mW
  • SSOP-28 PACKAGE
  • APPLICATIONS
    • DATA ACQUISITION
    • TEST AND MEASUREMENT
    • INDUSTRIAL PROCESS CONTROL
    • MEDICAL INSTRUMENTS
    • LABORATORY EQUIPMENT
All trademarks are the property of their respective owners.
The ADS7842 is a complete, 4-channel, 12-bit Analog-to-Digital Converter (ADC). It contains a 12-bit, capacitorbased, Successive Approximation Register (SAR) ADC with a sample-and-hold amplifier, interface for microprocessor use, and parallel, 3-state output drivers. The ADS7842 is specified at a 200kHz sampling rate while dissipating only 2mW of power. The reference voltage can be varied from 100mV to VCC with a corresponding LSB resolution from 24μV to 1.22mV. The ADS7842 is tested down to 2.7V operation.
Low power, high speed, and an onboard multiplexer make the ADS7842 ideal for battery-operated systems such as portable, multi-channel dataloggers and measurement equipment. The ADS7842 is available in an SSOP-28 package and is tested over the -40°C to +85°C temperature range.
