公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有内部采样和保持功能的 12 位、5MHz、自校准、流水线模数转换器
Sample rate (Max) (MSPS) 5
Resolution (Bits) 12
Number of input channels 1
Interface type Parallel CMOS, TTL
Analog input BW (MHz) 100
Features Low Power
Rating Catalog
Input range (Vp-p) 2
Power consumption (Typ) (mW) 105
Architecture Pipeline
SNR (dB) 68
ENOB (Bits) 10.9
SFDR (dB) 79
Operating temperature range (C) -20 to 75
Input buffer No
  • Single 5V Power Supply
  • Simple Analog Input Interface
  • Internal Sample-and-Hold
  • Internal Reference Buffer Amplifier
  • Low Power Consumption
The ADC12081 is a monolithic CMOS analog-to-digital converter capable of converting analog input signals into 12-bit digital words at 5 megasamples per second (MSPS). The ADC12081 utilizes an innovative pipeline architecture to minimize die size and power consumption. The ADC12081 uses self-calibration and error correction to maintain accuracy and performance over temperature.
The ADC12081 converter operates on a 5V power supply and can digitize analog input signals in the range of 0 to 2V. A single convert clock controls the conversion operation. All digital I/O is TTL compatible.
The ADC12081 is designed to minimize external components necessary for the analog input interface. An internal sample-and-hold circuit samples the analog input and an internal amplifier buffers the reference voltage input.
The ADC12081 is available in the 32-lead LQFP package and is designed to operate over the extended commercial temperature range of -40°C to +85°C.
