公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
12 位 200kSPS 微功耗采样模数转换器
Resolution (Bits) 12
Number of input channels 1
Sample rate (Max) (kSPS) 200
Interface type SPI
Architecture SAR
Input type Pseudo-Differential, Single-Ended
Rating Catalog
Reference mode Ext
Input range (Max) (V) 5.25
Input range (Min) (V) 0
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 1.6
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 71
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 0.75
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 200kHz Sampling Rate
  • microPower:
      1.6mW at 200kHz
      0.54mW at 75kHz
      0.06mW at 7.5kHz
  • Power Down: 3μA max
  • Mini-DIP-8, SO-8, and MSOP-8 Packages
  • Pseudo-Differential Input
  • Serial Interface
  • APPLICATIONS
    • Battery-Operated Systems
    • Remote Data Acquisition
    • Isolated Data Acquisition
    • Simultaneous Sampling, Multichannel Systems
All trademarks are the property of their respective owners.
The ADS7822 is a 12-bit sampling analog-to-digital (A/D) converter with ensured specifications over a 2.7V to 5.25V supply range. It requires very little power even when operating at the full 200kHz rate. At lower conversion rates, the high speed of the device enables it to spend most of its time in the power-down mode?the power dissipation is less than 60μW at 7.5kHz.
The ADS7822 also features operation from 2.0V to 5V, a synchronous serial interface, and a pseudo-differential input. The reference voltage can be set to any level within the range of 50mV to VCC.
Ultra low power and small size make the ADS7822 ideal for battery-operated systems. It is also a perfect fit for remote data-acquisition modules, simultaneous multichannel systems, and isolated data acquisition. The ADS7822 is available in a plastic mini-DIP-8, an SO-8, or an MSOP-8 package.
