公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
低功耗串行 12 位采样模数转换器
Resolution (Bits) 12
Number of input channels 1
Sample rate (Max) (kSPS) 40
Interface type SPI
Architecture SAR
Input type Single-Ended
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 10
Input range (Min) (V) -10
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 35
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 74
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 0.5
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 20μs max CONVERSION TIME
  • SINGLE +5V SUPPLY OPERATION
  • PIN-COMPATIBLE WITH 16-BIT ADS7813
  • EASY-TO-USE SERIAL INTERFACE
  • 0.3" DIP-16 AND SO-16
  • ±0.5LSB max INL AND DNL
  • 72dB min SINAD
  • USES INTERNAL OR EXTERNAL REFERENCE
  • MULTIPLE INPUT RANGES
  • 35mW max POWER DISSIPATION
  • NO MISSING CODES
  • 50μW POWER DOWN MODE
  • APPLICATIONS
    • DATA ACQUISITION SYSTEMS
    • INDUSTRIAL CONTROL
    • TEST EQUIPMENT
    • DIGITAL SIGNAL PROCESSING
Note: Recommended Voltage Reference: REF02 and REF102
All trademarks are the property of their respective owners.
The ADS7812 is a low-power, single +5V supply, 12-bit sampling analog-to-digital converter. It contains a complete 12-bit capacitor-based SAR A/D with a sample/hold, clock, reference, and serial data interface.
The converter can be configured for a variety of input ranges including ±10V, ±5V, 0V to 10V, and 0.5V to 4.5V. A high impedance 0.3V to 2.8V input range is also available (input impedance > 10M). For most input ranges, the input voltage can swing to +16.5V or ?16.5V without damage to the converter.
A flexible SPI compatible serial interface allows data to be synchronized to an internal or external clock. The ADS7812 is specified at a 40kHz sampling rate over the ?40°C to +85°C temperature range. It is available in a 0.3" DIP-16 or an SO-16 package.
