Resolution (Bits) | 16 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 250 |
Interface type | Parallel |
Architecture | SAR |
Input type | Single-Ended |
Rating | Catalog |
Reference mode | Ext, Int |
Input range (Max) (V) | 2.5 |
Input range (Min) (V) | -2.5 |
Operating temperature range (C) | -25 to 85 |
Power consumption (Typ) (mW) | 200 |
Analog voltage AVDD (Min) (V) | 4.75 |
SNR (dB) | 82 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 4 |
Digital supply (Min) (V) | 4.75 |
Digital supply (Max) (V) | 5.25 |
- 250kHz SAMPLING RATE
- COMPLETE WITH S/H, REF, CLOCK, ETC.
- 96dB min SFDR WITH 100kHz INPUT
- 82dB min SINAD WITH 100kHz INPUT
- ±2.5V INPUT RANGE
- 28–LEAD SOIC
- APPLICATIONS
- WIRELESS BASE STATIONS
- SPECTRUM ANALYSIS
- IMAGING SYSTEMS
- DATA ACQUISITION
All trademarks are the property of their respective owners.
The ADS7815 is a complete 16?bit sampling analog?todigital (A/D) converter featuring excellent AC performance and a 250kHz throughput rate. The design includes a 16?bit capacitor?based SAR A/D converter with an inherent sample and hold (S/H), a precision reference, and an internal clock. Spurious?free dynamic range with a 100kHz full?scale sinewave input is typically greater than 100dB. The ±2.5V input range allows development of precision systems using only ±5V supplies. The converter is available in a 28?lead SOIC package specified for operation over the industrial ?25°C to +85°C temperature range.
