Resolution (Bits) | 12 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 20 |
Interface type | SPI |
Architecture | SAR |
Input type | Single-Ended |
Rating | Catalog |
Reference mode | Ext |
Input range (Max) (V) | 5.25 |
Input range (Min) (V) | 0 |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 1.25 |
Analog voltage AVDD (Min) (V) | 4.5 |
SNR (dB) | 72 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 2 |
Digital supply (Min) (V) | 4.5 |
Digital supply (Max) (V) | 5.25 |
- SERIAL INTERFACE
- GUARANTEED NO MISSING CODES
- 20kHz SAMPLING RATE
- LOW SUPPLY CURRENT: 250μA
- Applications
- REMOTE DATA ACQUISITION
- ISOLATED DATA ACQUISITION
- TRANSDUCER INTERFACE
- BATTERY OPERATED SYSTEMS
The ADS1286 is a 12-bit, 20kHz analog-to-digital converter with a differential input and sample and hold amplifier and consumes only 250μA of supply current. The ADS1286 offers an SPI and SSI compatible serial interface for communications over a two or three wire interface. The combination of a serial two wire interface and micropower consumption makes the ADS1286 ideal for remote applications and for those requiring isolation.
The ADS1286 is available in a 8-pin plastic mini DIP and a 8-lead SOIC.
