Sample rate (Max) (MSPS) | 10 |
Resolution (Bits) | 12 |
Number of input channels | 1 |
Interface type | Parallel CMOS |
Analog input BW (MHz) | 65 |
Features | Low Power |
Rating | Catalog |
Input range (Vp-p) | 1.25, 3.25 |
Power consumption (Typ) (mW) | 260 |
Architecture | Pipeline |
SNR (dB) | 67 |
ENOB (Bits) | 10.7 |
SFDR (dB) | 77 |
Operating temperature range (C) | -40 to 85 |
Input buffer | Yes |
- NO MISSING CODES
- LOW POWER:250mW
- INTERNAL REFERENCE
- WIDEBAND TRACK-AND-HOLD:65MHz
- SINGLE +5V SUPPLY
- APPLICATIONS
- IF AND BASEBAND DIGITIZATION
- DATA ACQUISITION CARDS
- TEST INSTRUMENTATION
- CCD IMAGING
- Copiers
- Scanners
- Cameras
- VIDEO DIGITIZING
- GAMMA CAMERAS
All trademarks are the property of their respective owners.
The ADS802 is a low-power, monolithic 12-bit, 10MHz Analog-to-Digital (A/D) converter utilizing a small geometry CMOS process. This complete converter includes a 12-bit quantizer, wideband track-and-hold, reference and three-state outputs. It operates from a single +5V power supply and can be configured to accept either differential or single-ended input signals.
The ADS802 employs digital error correction in order to provide excellent Nyquist differential linearity performance for demanding imaging applications. Its low distortion, high SNR, and high-oversampling capability give it the extra margin needed for telecommunications, test instrumentation, and video applications.
This high-performance A/D converter is specified for ac and DC performance at a 10MHz sampling rate. The ADS802 is available in an SO-28 package.
