公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
12 位、25MSPS ADC 单端/差分输入内部基准电压,引脚与 ADS800/2 兼容
Sample rate (Max) (MSPS) 25
Resolution (Bits) 12
Number of input channels 1
Interface type Parallel CMOS
Analog input BW (MHz) 65
Features Low Power
Rating Catalog
Input range (Vp-p) 2
Power consumption (Typ) (mW) 270
Architecture Pipeline
SNR (dB) 66
ENOB (Bits) 10.3
SFDR (dB) 77
Operating temperature range (C) -40 to 85
Input buffer No
  • NO MISSING CODES
  • LOW POWER:270mW
  • INTERNAL REFERENCE
  • WIDEBAND TRACK-AND-HOLD:65MHz
  • SINGLE +5V SUPPLY
  • PACKAGE:SO-28 and SSOP-28
  • APPLICATIONS
    • IF AND BASEBAND DIGITIZATION
    • DIGITAL COMMUNICATIONS
    • TEST INSTRUMENTATION
    • CCD IMAGING
      • Copiers
      • Scanners
      • Cameras
    • VIDEO DIGITIZING
    • GAMMA CAMERAS
All trademarks are the property of their respective owners.
The ADS801 is a low-power, monolithic 12-bit, 25MHz Analog-to-Digital (A/D) converter utilizing a small geometry CMOS process. This complete converter includes a 12-bit quantizer, wideband track-and-hold, reference, and three-state outputs. It operates from a single +5V power supply and can be configured to accept either single-ended or differential input signals.
The ADS801 employs digital error correction to provide excellent Nyquist differential linearity performance for demanding imaging applications. Its low distortion, high SNR, and high-oversampling capability give it the extra margin needed for telecommunications, instrumentation, and video applications.
This high-performance A/D converter is specified over temperature for ac and DC performance at a 25MHz sampling rate. The ADS820 is available in an SO-28 package.
