公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
16 位 10us 串行 CMOS 采样模数转换器
Resolution (Bits) 16
Number of input channels 1
Sample rate (Max) (kSPS) 100
Interface type SPI
Architecture SAR
Input type Single-Ended
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 10
Input range (Min) (V) -10
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 81.5
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 88
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 2
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 100kHz SAMPLING RATE
  • 86dB SINAD WITH 20kHz INPUT
  • ±2LSB INL
  • DNL: 16 Bits No Missing Codes
  • SIX SPECIFIED INPUT RANGES
  • SERIAL OUTPUT
  • SINGLE +5V SUPPLY OPERATION
  • PIN-COMPATIBLE WITH 12-BIT ADS7808
  • USES INTERNAL OR EXTERNAL REFERENCE
  • 100mW MAX POWER DISSIPATION
  • 0.3" SO-20
  • SIMPLE DSP INTERFACE
Note: Recommended Voltage Reference: REF02 and REF102
All trademarks are the property of their respective owners.
The ADS7809 is a complete 16-bit sampling Analog-to-Digital (A/D) converter using state-of-the-art CMOS structures. It contains a 16-bit capacitor-based Successive Approximation Register (SAR) A/D converter with sample-and-hold, reference, clock, and a serial data interface. Data can be outputted using the internal clock, or can be synchronized to an external data clock. The ADS7809 also provides output synchronization pulse for ease of use with standard DSP processors.
The ADS7809 is specified at a 100kHz sampling rate, and specified over the full temperature range. Laser-trimmed scaling resistors provide various input ranges including ±10V and 0V to 5V, while an innovative design operates from single +5V supply, with power dissipation under 100mW.
The ADS7809 is available in a 0.3" SO-20, and is fully specified for operation over the industrial ?40°C to +85°C range.
