Resolution (Bits) | 12 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 100 |
Interface type | Byte-Wide, Parallel |
Architecture | SAR |
Input type | Single-Ended |
Rating | Catalog |
Reference mode | Ext, Int |
Input range (Max) (V) | 10 |
Input range (Min) (V) | -10 |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 81.5 |
Analog voltage AVDD (Min) (V) | 4.75 |
SNR (dB) | 70 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 0.45 |
Digital supply (Min) (V) | 4.75 |
Digital supply (Max) (V) | 5.25 |
- 100kHz min SAMPLING RATE
- STANDARD ±10V INPUT RANGE
- 72dB min SINAD WITH 45kHz INPUT
- ±0.45 LSB max INL
- DNL: 12 Bits "No Missing Codes"
- SINGLE +5V SUPPLY OPERATION
- PIN-COMPATIBLE WITH 16-BIT ADS7805
- USES INTERNAL OR EXTERNAL REFERENCE
- COMPLETE WITH S/H, REF, CLOCK, ETC.
- FULL PARALLEL DATA OUTPUT
- 100mW max POWER DISSIPATION
- 28-PIN 0.3" PLASTIC DIP AND SO PACKAGES
Note: Recommended Voltage Reference: REF02 and REF102
The ADS7804 is a complete 12-bit sampling analog-to-digital (A/D) converter using state-of-the-art CMOS structures. It contains a complete 12-bit, capacitor-based, SAR A/D converter with S/H, reference, clock, interface for microprocessor use, and three-state output drivers.
The ADS7804 is specified at a 100kHz sampling rate, and guaranteed over the full temperature range. Laser-trimmed scaling resistors provide an industry-standard ±10V input range, while the innovative design allows operation from a single +5V supply, with power dissipation under 100mW.
The 28-pin ADS7804 is available in plastic 0.3" DIP and SO packages, both fully specified for operation over the industrial ?40°C to +85°C range.
