公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
12 位 3us 采样 模数转换器
Resolution (Bits) 12
Number of input channels 1
Sample rate (Max) (kSPS) 333
Interface type Byte-Wide, Parallel
Architecture SAR
Input type Single-Ended
Rating Catalog
Reference mode Int
Input range (Max) (V) 10
Input range (Min) (V) -10
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 135
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 73
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 0.5
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 333k SAMPLES PER SECOND
  • STANDARD ±10V AND ±5V INPUT RANGES
  • DC PERFORMANCE OVER TEMP:
    • No Missing Codes
    • 1/2LSB Integral Linearity Error
    • 3/4LSB Differential Linearity Error
  • AC PERFORMANCE OVER TEMP:
    • 72dB Signal-to-Noise Ratio
    • 80dB Spurious-free Dynamic Range
    • –80dB Total Harmonic Distortion
  • INTERNAL SAMPLE/HOLD, REFERENCE, CLOCK, AND THREE-STATE OUTPUTS
  • POWER DISSIPATION: 215mW max
  • PACKAGE:
    • 24-Pin Single-Wide DIP
    • 24-Lead SOIC
Note: Recommended Voltage Reference: REF02 and REF102
All trademarks are teh property of their respective owners.
The ADS7800 is a complete 12-bit sampling analog-to-digital converter using state-of-the-art CMOS structures. It contains a complete 12-bit successive approximation A/D converter with internal sample/hold, reference, clock, digital interface for microprocessor control, and three-state output drivers.
The ADS7800 is specified at a 333kHz sampling rate. Conversion time is factory set for 2.70μs max over temperature, and the high speed sampling input stage insures a total acquisition and conversion time of 3μs max over temperature. Precision, laser-trimmed scaling resistors provide industry-standard input ranges of ±5V or ±10V.
AC and DC performance are completely specified. Two grades based on linearity and dynamic performance are available to provide the optimum price/performance fit in a wide range of applications.
The 24-pin ADS7800 is available in plastic and side-braze hermetic 0.3" wide DIPs, and in an SOIC package. It operates from a +5V supply and either a ?12V or ?15V supply. The ADS7800 is available in grades specified over 0°C to +70°C and ?40°C to +85°C temperature ranges.
