公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有多路复用器选项的 8 位、8 通道、微处理器兼容模数转换器
Resolution (Bits) 8
Number of input channels 8
Sample rate (Max) (kSPS) 25
Interface type Parallel
Architecture SAR
Input type Differential, Pseudo-Differential, Single-Ended
Multi-channel configuration Multiplexed
Rating Catalog
Reference mode Ext
Input range (Max) (V) 6
Input range (Min) (V) 0
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 5
Analog voltage AVDD (Min) (V) 4.5
Analog voltage AVDD (Max) (V) 6
INL (Max) (+/-LSB) 1
Digital supply (Min) (V) 4.5
Digital supply (Max) (V) 6
  • Easy Interface to All Microprocessors
  • Operates Ratiometrically or with 5 VDC Voltage Reference
  • No Zero or Full-Scale Adjust Required
  • 4-Channel or 8-Channel Multiplexer with Address Logic
  • Internal Clock
  • 0V to 5V Input Range with Single 5V Power Supply
  • Standard Width 20-Pin or 24-Pin PDIP
  • 28 Pin PLCC Package
Key Specifications
  • Resolution: 8 Bits
  • Total Unadjusted Error: ±? LSB and ± 1 LSB
  • Single Supply: 5 VDC
  • Low Power: 15 mW
  • Conversion Time: 40 μs
All trademarks are the property of their respective owners.
The ADC0844 and ADC0848 are CMOS 8-bit successive approximation A/D converters with versatile analog input multiplexers. The 4-channel or 8-channel multiplexers can be software configured for single-ended, differential or pseudo-differential modes of operation.
The differential mode provides low frequency input common mode rejection and allows offsetting the analog range of the converter. In addition, the A/D's reference can be adjusted enabling the conversion of reduced analog ranges with 8-bit resolution.
The A/Ds are designed to operate from the control bus of a wide variety of microprocessors. TRI-STATE output latches that directly drive the data bus permit the A/Ds to be configured as memory locations or I/O devices to the microprocessor with no interface logic necessary.
