公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有非易失性存储器的 256 抽头双通道数字电位计
Number of steps 256
Number of channels (#) 2
Resistance taper Linear
Interface type I2C
Memory Non-Volatile
Bandwidth (MHz) 0.25
Temp coeff (Typ) (ppm/ degree C) 130
Operating temperature range (C) -40 to 125
  • Dual-Channel, 256-Position Resolution
  • Non-Volatile Memory Stores Wiper Settings
  • 2-mm × 2-mm, 14-Pin TSSOP Package
  • 100-kΩ End-to-End Resistance (TPL0102-100)
  • Fast Power-Up Response Time to Wiper Setting:
    <100 μs
  • ±0.5 LSB INL, ±0.25 LSB DNL
    (Voltage-Divider Mode)
  • 4 ppm/°C Ratiometric Temperature Coefficient
  • I2C-Compatible Serial Interface
  • 2.7- to 5.5-V Single-Supply Operation
  • ±2.25 to ±2.75 V Dual-Supply Operation
  • Operating Temperature Range From
    –40°C to 125°
  • ESD Performance Tested Per JESD 22
    • 2000-V Human Body Model
      (A114-B, Class II)
  • Supports Defense, Aerospace, and Medical Applications
    • Controlled Baseline
    • One Assembly and Test Site
    • One Fabrication Site
    • Available in Extended (Q) Temperature –40°c to
      125°C
    • Extended Product Life Cycle
    • Extended Product-Change Notification
    • Product Traceability
The TPL0102-EP is a two-channel, linear-taper digital potentiometer with 256 wiper positions. Each potentiometer can be used as a three-terminal potentiometer or as a two-terminal rheostat. The TPL0102-EP-100 has an end-to-end resistance of 100 kΩ.
The TPL0102-EP has non-volatile memory (EEPROM) which can be used to store the wiper position. The internal registers of the TPL0102-EP can be accessed using the I2C interface.
The TPL0102-EP is available in a 14-pin TSSOP package with a specified temperature range of ?40°C to 125°C.
