1 / 1
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  210粉丝
--- 产品详情 ---
单通道 16 位低干扰噪声、无缓冲电压输出数模转换器 (DAC)
Resolution (Bits) 16
Number of DAC channels (#) 1
Interface type SPI
Output type Unbuffered Voltage
Settling time (μs) 1
Features Small Size
Architecture R-2R
Rating Catalog
Output range (Max) (mA/V) 5.5
Output range (Min) (mA/V) 0
Operating temperature range (C) -40 to 85
  • 16-bit performance: 1-LSB DNL and 2-LSB INL
  • Low glitch energy: 0.5 nV-s
  • Fast settling: 1 μs
  • Wide power supply: 2.7 V to 5.5 V
  • Wide reference range: 2.0 V to VDD
  • Low power: 250 μA at 5.0 V
  • 3-wire serial peripheral interface (SPI) up to 50?MHz
  • Reset to zero scale or midscale
  • 1.62-V VIH with VDD = 5.5 V
  • Temperature range: –40°C to +85°C
  • Package: Tiny 10-pin WSON
The 16-bit DAC82001 is a highly accurate, low-power, single-channel digital-to-analog converter (DAC) with an unbuffered voltage output.
The DAC82001 works with 3.3-V and 5-V supplies and offers linearity of 1?SB DNL and 2?LSB INL. The high accuracy combined with a tiny package make the device an excellent choice for applications such as gain and offset calibration, voltage set point generation, and power-supply control. The DAC82001 incorporates a power-on-reset (POR) circuit. The POR circuit makes sure that the DAC output powers up at zero scale or midscale based on the status of RSTSEL pin, and remains at that scale until a valid code is written to the device. All internal registers are asynchronously reset after the RESET pin is pulled low.
The DAC82001 uses a versatile, three-wire serial peripheral interface (SPI) that operates at clock rates of up to 50?MHz.
