Resolution (Bits) | 10 |
Number of DAC channels (#) | 8 |
Interface type | SPI |
Output type | Buffered Voltage |
Settling time (μs) | 10 |
Features | Cost Optimized, Small Size |
Reference type | Ext |
Architecture | String |
Rating | Catalog |
Output range (Max) (mA/V) | 5.5 |
Output range (Min) (mA/V) | 0 |
Operating temperature range (C) | -40 to 125 |
- ±1-LSB INL and DNL
- Wide operating range
- Power supply: 1.8 V to 5.5 V
- Temperature range: –40°C to +125°C
- 3-wire SPI interface
- VIH = 2.4 V for 2.7 V ≤ VDD ≤ 5.5 V
- VIH = (VDD – 0.3 V) for 1.8 V ≤ VDD ≤ 2.7 V
- LDAC pin for simultaneous output update
- Very low power: 0.1 mA/channel at 1.8 V
- Low-power start-up mode: Outputs powered down with 10 k? to AGND.
- Tiny package
- 16-pin WQFN (3 mm × 3 mm)
The 10-bit DAC53508 and 8-bit DAC43508 ( DACx3508) are low-power, eight-channel, voltage-output, digital-to-analog converters (DACs). The DACx3508 are specified monotonic by design across a wide power supply range from 1.8?V to 5.5?V. Using an external reference, the DACx3508 provides a full-scale output voltage range of 1.8?V to 5.5?V while consuming 0.1?mA quiescent current per channel. The DACx3508 also includes per channel, user programmable, power down registers. These registers facilitate the DAC output buffers to start in a 10 k?-AGND power-down state, and remain in this state until a power-up command is issued to these output buffers.
Low quiescent current, wide power-supply range, octal channel, and a per-channel power-down option make the DACx3508 an excellent choice for high-density, low-power, battery-operated systems.
The devices communicate through the 3-wire (write-only) SPI interface. These devices also have a load DAC (LDAC) and clear CLR inputs.
