公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
汽车类 10 位 165MSPS 数模转换器 (DAC)
Resolution (Bits) 10
Number of DAC channels (#) 1
Interface type Parallel CMOS
Sample/update rate (MSPS) 200
Features Low Power
Rating Automotive
Interpolation 1x
Power consumption (Typ) (mW) 170
SFDR (dB) 76
Architecture Current Source
Operating temperature range (C) -40 to 125
Reference type Ext, Int
  • Qualified for Automotive Applications
  • Single +5V OR +3V Operation
  • High SFDR: 5MHz Output at 100MSPS: 68dBc
  • Low Glitch: 3pV-s
  • Low Power: 170mW at +5V
  • Internal Reference: Optional External Reference
    Adjustable Full-Scale Range Multiplying Option
  • Latch-Up Performance Meets 100 mA
    Per JESD 78, Class I
  • APPLICATIONS
    • Communication Transmit Channels
      • WLL, Cellular Base Station
      • Digital Microwave Links
      • Cable Modems
    • Waveform Generation
      • Direct Digital Synthesis (DDS)
      • Arbitrary Waveform Generation (ARB)
    • Medical/Ultrasound
    • High-Speed Instrumentation and Control
    • Video, Digital TV
The DAC900 is a high-speed, Digital-to-Analog Converter (DAC) offering a 10-bit resolution option within the SpeedPlus family of high-performance converters. Featuring pin compatibility among family members, the DAC908, DAC902, and DAC904 provide a component selection option to an 8-, 12-, and 14-bit resolution, respectively. All models within this family of DACs support update rates in excess of 165MSPS with excellent dynamic performance, and are especially suited to fulfill the demands of a variety of applications.
The advanced segmentation architecture of the DAC900 is optimized to provide a high Spurious-Free Dynamic Range (SFDR) for single-tone, as well as for multi-tone signals—essential when used for the transmit signal path of communication systems.
The DAC900 has a high impedance (200k) current output with a nominal range of 20mA and an output compliance of up to 1.25V. The differential outputs allow for both a differential or singleended analog signal interface. The close matching of the current outputs ensures superior dynamic performance in the differential configuration, which can be implemented with a transformer.
Utilizing a small geometry CMOS process, the monolithic DAC900 can be operated on a wide, single-supply range of +2.7V to +5.5V. Its low power consumption allows for use in portable and battery operated systems. Further optimization can be realized by lowering the output current with the adjustable full-scale option.
For noncontinuous operation of the DAC900, a power-down mode results in only 45mW of standby power.
The DAC900 comes with an integrated 1.24V bandgap reference and edge-triggered input latches, offering a complete converter solution. Both +3V and +5V CMOS logic families can be interfaced to the DAC900.
The reference structure of the DAC900 allows for additional flexibility by utilizing the on-chip reference, or applying an external reference. The full-scale output current can be adjusted over a span of 2mA to 20mA, with one external resistor, while maintaining the specified dynamic performance.
The DAC900 is available in a TSSOP-28 (PW) package.
