公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
16 位、1.0GSPS、1x-4x 内插数模转换器 (DAC)
Resolution (Bits) 16
Number of DAC channels (#) 1
Interface type Parallel LVDS
Sample/update rate (MSPS) 1000
Features Ultra High Speed
Rating Catalog
Interpolation 1x, 2x, 4x
Power consumption (Typ) (mW) 800
SFDR (dB) 81
Architecture Current Sink
Operating temperature range (C) -40 to 85
Reference type Int
  • 16-Bit Digital-to-Analog Converter (DAC)
  • 1.0 GSPS Update Rate
  • 16-Bit Wideband Input LVDS Data Bus
    • 8 Sample Input FIFO
  • High Performance
    • 73-dBc ACLR WCDMA TM1 at 180 MHz
  • 2x to 32x Clock Multiplying PLL/VCO
  • 2x or 4x Interpolation Filters
    • Stopband Transition 0.4–0.6 Fdata
    • Filters Configurable in Either Low-Pass or
      High-Pass Mode
      • Allows Selection of Higher Order Image
  • On-Chip 1.2-V Reference
  • 2 to 20-mA Differential Scalable Output
  • 64-Pin 9-mm × 9-mm VQFN Package
  • APPLICATIONS
    • Cellular Base Stations
    • Broadband Wireless Access (BWA)
    • WiMAX 802.16
    • Fixed Wireless Backhaul
    • Cable Modem Termination System (CMTS)
All other trademarks are the property of their respective owners
The DAC5681Z is a 16-bit 1.0 GSPS digital-to-analog converter (DAC) with wideband LVDS data input, integrated 2x to 4x interpolation filters, on-board clock multiplier, and internal voltage reference. The DAC5681Z offers superior linearity, noise, crosstalk, and PLL phase noise performance.
The DAC5681Z integrates a wideband LVDS port with on-chip termination. Full-rate input data can be transferred to a single DAC channel, or half-rate and 1/4-rate input data can be interpolated by on-board 2x or 4x FIR filters. Each interpolation FIR is configurable in either low-pass or high-pass mode, allowing selection of a higher order output spectral image. An on-chip delay lock loop (DLL) simplifies LVDS interfacing by providing skew control for the LVDS input data clock.
The DAC5681Z is characterized for operation over the industrial temperature range of ?40°C to 85°C and is available in a 64-pin VQFN package. Other members of the family include the dual-channel, interpolating DAC5682Z and the single-channel, non-interpolating DAC5681.
