公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
数模转换器;四路、16 位、12uS 稳定时间、+/- 1 LSB DNL
Resolution (Bits) 16
Number of DAC channels (#) 4
Interface type Parallel
Output type Buffered Voltage
Settling time (μs) 12
Features Reset to Mid-Scale
Reference type Ext, Int
Architecture R-2R
Rating Catalog
Output range (Max) (mA/V) 2.5
Output range (Min) (mA/V) -2.5
Operating temperature range (C) -40 to 85
  • Low Glitch: 1nV-s (typ)
  • Low Power: 18mW
  • Unipolar or Bipolar Operation
  • Settling Time: 12μs to 0.003%
  • 16-Bit Linearity and Monotonicity:
    ???–40°C to +85°C
  • Programmable Reset to Mid-Scale or Zero-Scale
  • Data Readback
  • Double-Buffered Data Inputs
  • Internal Bandgap Voltage Reference
  • Power-On Reset
  • 3V to 5V Logic Interface
  • APPLICATIONS
    • Process Control
    • Closed-Loop Servo Control
    • Motor Control
    • Data Acquisition Systems
    • DAC-per-Pin Programmers
All trademarks are the property of their respective owners.
The DAC7664 is a 16-bit, quad voltage output digital-to-analog converter (DAC) with 16-bit monotonic performance over the specified temperature range. It accepts 16-bit parallel input data, has double-buffered DAC input logic (allowing simultaneous update of all DACs), and provides a readback mode of the internal input registers. Programmable asynchronous reset clears all registers to a mid-scale code of 8000h or to a zero-scale of 0000h. The DAC7664 can operate from a single +5V supply or from +5V and ?5V supplies.
Low power and small size per DAC make the DAC7664 ideal for automatic test equipment, DAC-per-pin programmers, data acquisition systems, and closed-loop servo control. The DAC7664 is available in an LQFP-64 package and is specified for operation over the ?40°C to +85°C temperature range.
