| Resolution (Bits) | 16 |
| Number of DAC channels (#) | 2 |
| Interface type | Parallel |
| Output type | Buffered Voltage |
| Settling time (μs) | 10 |
| Features | Reset to Mid-Scale |
| Reference type | Ext |
| Architecture | R-2R |
| Rating | Catalog |
| Output range (Max) (mA/V) | 2.5 |
| Output range (Min) (mA/V) | -2.5 |
| Operating temperature range (C) | -40 to 85 |
- LOW POWER: 4mW
- UNIPOLAR OR BIPOLAR OPERATION
- SETTLING TIME: 10 us to 0.003% FSR
- 15-BIT LINEARITY AND MONOTONICITY: –40°C to +85°C
- RESET TO MID-SCALE (DAC7642) OR ZERO-SCALE (DAC7643)
- DATA READBACK
- DOUBLE-BUFFERED DATA INPUTS
- APPLICATIONS
- PROCESS CONTROL
- CLOSED-LOOP SERVO-CONTROL
- MOTOR CONTROL
- DATA ACQUISITION SYSTEMS
- DAC-PER-PIN PROGRAMMERS
The DAC7642 and DAC7643 are dual channel, 16-bit, voltage output Digital-to-Analog Converters (DACs) which provide 15-bit monotonic performance over the specified temperature range. They accept 16-bit parallel input data, have double-buffered DAC input logic (allowing simultaneous update of all DACs), and provide a readback mode of the internal input registers. Programmable asynchronous reset clears all registers to a mid-scale code of 8000H (DAC7642) or to a zero-scale code of 0000H (DAC7643). These DACs can operate from a single +5V supply or from +5V and ?5V supplies, providing an output range of 0 to +2.5V or ?2.5V to +2.5V, respectively.
Low power and small size per DAC make the DAC7642 and DAC7643 ideal for automatic test equipment, DAC-per-pin programmers, data acquisition systems, and closed-loop servo-control. The DAC7642 and DAC7643 are available in a LQFP-32 package and specified over a ?40°C to +85°C temperature range.
