公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有内部基准电压的 2.7V 至 5.5V 10 位 8 通道串行 DAC
Resolution (Bits) 10
Number of DAC channels (#) 8
Interface type SPI
Output type Buffered Voltage
Settling time (μs) 1
Features SDO
Reference type Ext, Int
Architecture String
Rating Catalog
Output range (Max) (mA/V) 5.1
Output range (Min) (mA/V) 0
Operating temperature range (C) -40 to 85
  • Eight Voltage Output DACs in One Package
    • TLV5630 . . .12-Bit
    • TLV5631 . . .10-Bit
    • TLV5632 . . .8-Bit
    • 1 μs in Fast Mode
    • 3 μs in Slow Mode
  • Programmable Settling Time vs Power
    Consumption
    • 1 μs in Fast Mode
    • 3 μs in Slow Mode
    • 18 mW in Slow Mode at 3 V
    • 48 mW in Fast Mode at 3 V
  • Compatible With TMS320 and SPI Serial Ports
  • Monotonic Over Temperature
  • Low Power Consumption:
  • Power-Down Mode
  • Internal Reference
  • Data Output for Daisy-Chaining
  • APPLICATIONS
    • Digital Servo Control Loops
    • Digital Offset and Gain Adjustment
    • Industrial Process Control
    • Machine and Motion Control Devices
    • Mass Storage Devices
The TLV5630, TLV5631, and TLV5632 are pin-compatible,eight-channel, 12-/10-/8-bit voltage output DACs each with a flexible serial interface. The serial interface allows glueless interface to TMS320 and SPI, QSPI, and Microwire serial ports. It is programmed with a 16-bit serial string containing 4 control and 12 data bits.
Additional features are a power-down mode, an LDAC input for simultaneous update of all eight DAC outputs, and a data output which can be used to cascade multiple devices, and an internal programmable band-gap reference.
The resistor string output voltage is buffered by a rail-to-rail output amplifier with a programmable settling time to allow the designer to optimize speed vs power dissipation. The buffered, high-impedance reference input can be connected to the supply voltage.
Implemented with a CMOS process, the DACs are designed for single-supply operation from 2.7 V to 5.5 V, and can operate on two separate analog and digital power supplies. The devices are available in 20-pin SOIC and TSSOP packages.
