| Resolution (Bits) | 10 |
| Number of DAC channels (#) | 1 |
| Interface type | Parallel CMOS |
| Sample/update rate (MSPS) | 200 |
| Features | Low Power |
| Rating | Catalog |
| Interpolation | 1x |
| Power consumption (Typ) (mW) | 170 |
| SFDR (dB) | 76 |
| Architecture | Current Source |
| Operating temperature range (C) | -40 to 85 |
| Reference type | Ext, Int |
- SINGLE +5V OR +3V OPERATION
- HIGH SFDR: 5MHz Output at 100MSPS: 68dBc
- LOW GLITCH: 3pV-s
- LOW POWER: 170mW at +5V
- INTERNAL REFERENCE:
?????Optional Ext. Reference
?????Adjustable Full-Scale Range
?????Multiplying Option - APPLICATIONS
- COMMUNICATION TRANSMIT CHANNELS
?????WLL, Cellular Base Station
?????Digital Microwave Links
?????Cable Modems - WAVEFORM GENERATION
?????Direct Digital Synthesis (DDS)
?????Arbitrary Waveform Generation (ARB) - MEDICAL/ULTRASOUND
- HIGH-SPEED INSTRUMENTATION AND CONTROL
- VIDEO, DIGITAL TV
The DAC900 is a high-speed, Digital-to-Analog Converter (DAC) offering a 10-bit resolution option within the SpeedPlus family of high-performance converters. Featuring pin compatibility among family members, the DAC908, DAC902, and DAC904 provide a component selection option to an 8-, 12-, and 14-bit resolution, respectively. All models within this family of DACs support update rates in excess of 165MSPS with excellent dynamic performance,and are especially suited to fulfill the demands of a variety of applications.
The advanced segmentation architecture of the DAC900 is optimized to provide a high Spurious-Free Dynamic Range (SFDR) for single-tone, as well as for multi-tone signals?essential when used for the transmit signal path of communication systems.
The DAC900 has a high impedance (200k
) current output with a nominal range of 20mA and an output compliance of up to 1.25V. The differential outputs allow for both a differential or single-ended analog signal interface. The close matching of the current outputs ensures superior dynamic performance in the differential configuration, which can be implemented with a transformer.
Utilizing a small geometry CMOS process, the monolithic DAC900 can be operated on a wide, single-supply range of +2.7V to +5.5V. Its low power consumption allows for use in portable and battery-operated systems. Further optimization can be realized by lowering the output current with the adjustable full-scale option.
For noncontinuous operation of the DAC900, a power-down mode results in only 45mW of standby power.
The DAC900 comes with an integrated 1.24V bandgap reference and edge-triggered input latches, offering a complete converter solution. Both +3V and +5V CMOS logic families can be interfaced to the DAC900.
The reference structure of the DAC900 allows for additional flexibility by utilizing the on-chip reference, or applying an external reference. The full-scale output current can be adjusted over a span of 2mA to 20mA, with one external resistor, while maintaining the specified dynamic performance.
The DAC900 is available in SO-28 and TSSOP-28 packages.
