公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
10 位、1us 双路 DAC,具有串行输入、双路 DAC、可编程内部基准、稳定时间
Resolution (Bits) 10
Number of DAC channels (#) 2
Interface type SPI
Output type Buffered Voltage
Settling time (μs) 0.8
Reference type Ext, Int
Architecture String
Rating Catalog
Output range (Max) (mA/V) 5.1
Output range (Min) (mA/V) 0
Operating temperature range (C) -40 to 85, 0 to 70
  • Dual 10-Bit Voltage Output DAC
  • Programmable Internal Reference
  • Programmable Settling Time:
    • 0.8μs in Fast Mode
    • 2.8μs in Slow Mode
  • Compatible With TMS320 and SPI? Serial Ports
  • Differential Nonlinearity <0.1LSB Typ
  • Monotonic Over Temperature
  • APPLICATIONS
    • Digital Servo Control Loops
    • Digital Offset and Gain Adjustment
    • Industrial Process Control
    • Machine and Motion Control Devices
    • Mass Storage Devices
SPI, QSPI are trademarks of Motorola, Inc.
Microwire is a trademark of National Semiconductor Corporation.
All other trademarks are the property of their respective owners.
The TLV5637 is a dual 10-bit voltage output DAC with a flexible 3-wire serial interface. The serial interface allows glueless interface to TMS320 and SPI?, QSPI?, and Microwire? serial ports. It is programmed with a 16-bit serial string containing 2 control and 10 data bits.
The resistor string output voltage is buffered by a x2 gain rail-to-rail output buffer. The buffer features a Class AB output stage to improve stability and reduce settling time. The programmable settling time of the DAC allows the designer to optimize speed versus power dissipation. With its on-chip programmable precision voltage reference, the TLV5637 simplifies overall system design.
Because of its ability to source up to 1mA, the reference can also be used as a system reference. Implemented with a CMOS process, the device is designed for single supply operation from 2.7V to 5.5V. It is available in an 8-pin SOIC package to reduce board space in standard commercial and industrial temperature ranges.
