| Resolution (Bits) | 16 |
| Number of DAC channels (#) | 4 |
| Interface type | Parallel |
| Output type | Buffered Voltage |
| Settling time (μs) | 10 |
| Features | Reset to Mid-Scale |
| Reference type | Ext |
| Architecture | R-2R |
| Rating | Catalog |
| Output range (Max) (mA/V) | 2.5 |
| Output range (Min) (mA/V) | -2.5 |
| Operating temperature range (C) | -40 to 85 |
- LOW POWER: 10mW<
- UNIPOLAR OR BIPOLAR OPERATION
- SETTLING TIME: 10μs to 0.003%
- 15-BIT LINEARITY AND MONOTONICITY:
–40°C to +85°C - PROGRAMMABLE RESET TO MID-SCALE OR
ZERO-SCALE - DATA READBACK
- DOUBLE-BUFFERED DATA INPUTS
The DAC7644 is a 16-bit, quad voltage output digital-to-analog converter with guaranteed 15-bit monotonic performance over the specified temperature range. It accepts 16-bit parallel input data, has double-buffered DAC input logic (allowing simultaneous update of all DACs), and provides a readback mode of the internal input registers. Programmable asynchronous reset clears all registers to a mid-scale code of 8000H or to a zero-scale of 0000H. The DAC7644 can operate from a single +5V supply or from +5V and ?5V supplies.
Low power and small size per DAC make the DAC7644 ideal for automatic test equipment, DAC-per-pin programmers, data acquisition systems, and closed-loop servo-control. The DAC7644 is available in a 48-lead SSOP package and offers guaranteed specifications over the ?40°C to +85°C temperature range.
