公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
20 位 Δ-Σ 低功耗数模转换器
Resolution (Bits) 20
Number of DAC channels (#) 1
Interface type SPI
Output type Unbuffered Voltage
Settling time (μs) 2000
Features On-chip Offset and Gain Calibration
Reference type Ext
Architecture Delta-Sigma
Rating Catalog
Output range (Max) (mA/V) 5.5
Output range (Min) (mA/V) 0
Operating temperature range (C) -40 to 85
  • 20-Bit Monotonicity Ensured Over –40°C to +85°C
  • Low Power: 2.5mW
  • Voltage Output
  • Settling Time: 2ms to 0.012%
  • Maximum Linearity Error: ±0.0015%
  • On-Chip Calibration
  • APPLICATIONS
    • Process Control
    • ATE Pin Electronics
    • Closed-Loop Servo Control
    • Smart Transmitters
    • Portable Instruments
All trademarks are the property of their respective owners.
The DAC1220 is a 20-bit digital-to-analog (D/A) converter offering 20-bit monotonic performance over the specified temperature range. It utilizes delta-sigma technology to achieve inherently linear performance in a small package at very low power. The resolution of the device can be programmed to 20 bits for Full-Scale, settling to 0.003% within 15ms typical, or 16 bits for Full-Scale, settling to 0.012% within 2ms max. The output range is two times the external reference voltage. On-chip calibration circuitry dramatically reduces low offset and gain errors.
The DAC1220 features a synchronous serial interface; in single-converter applications, the serial interface can be accomplished with just two wires, allowing low-cost isolation. For multiple converters, a CS signal allows for selection of the appropriate D/A converter.
The DAC1220 has been designed for closed-loop control applications in the industrial process control market and high-resolution applications in the test and measurement market. It is also ideal for remote applications, battery-powered instruments, and isolated systems. The DAC1220 is available in an SSOP-16 package.
