| Resolution (Bits) | 16 |
| Number of DAC channels (#) | 1 |
| Interface type | Parallel |
| Output type | Buffered Voltage |
| Settling time (μs) | 10 |
| Features | On-chip Offset and Gain Calibration, Reset to Mid-Scale |
| Reference type | Int |
| Architecture | R-2R |
| Rating | Catalog |
| Output range (Max) (mA/V) | 10 |
| Output range (Min) (mA/V) | 0 |
| Operating temperature range (C) | -40 to 85, 0 to 70 |
- HIGH-SPEED 16-BIT PARALLEL DOUBLE-BUFFERED INTERFACE
- VOLTAGE OUTPUT: 0 to +10V
- 13-, 14-, 15-BIT LINEARITY GRADES
- 16-BIT MONOTONIC OVER TEMPERATURE (L GRADE)
- POWER DISSIPATION: 600mW max
- GAIN AND OFFSET ADJUST: Convenient for Auto-Cal D/A Converters
- 28-LEAD DIP AND SOIC PACKAGES
The DAC715 is a complete monolithic digital-to-analog converter including a +10V temperature compensated reference, current-to-voltage amplifier, 16-bit parallel interface that is double buffered, and an asynchronous clear function which immediately sets the output voltage to one-half of full-scale.
The output voltage range is 0 to +10V while operating from ±12V or ±15V supplies. The gain and bipolar offset adjustments are designed so that they can be set via external potentiometers or external D/A converters. The output amplifier is protected against short circuit to ground.
The 28-pin DAC715 is available in a 0.3" plastic DIP and wide-body plastic SOIC package. The DAC715P, U, PB, and UB are specified over the ?40°C to +85°C temperature range while the DAC715PK, UK, PL, and UL are specified over the 0°C to +70°C range.
