| Resolution (Bits) | 8 |
| Number of DAC channels (#) | 2 |
| Interface type | Parallel |
| Output type | Unbuffered Current |
| Settling time (μs) | 0.1 |
| Reference type | Ext |
| Architecture | Multiplying DAC |
| Rating | Catalog |
| Output range (Max) (mA/V) | 2 |
| Output range (Min) (mA/V) | -2 |
| Operating temperature range (C) | 0 to 70 |
- Easy Microprocessor Interface
- On-Chip Data Latches
- Digital Inputs Are TTL-Compatible With 10.8-V to 15.75-V Power Supply
- Monotonic Over the Entire A/D Conversion Range
- Fast Control Signaling for Digital Signal Processor (DSP) Applications Including Interface With TMS320
- CMOS Technology
- KEY PERFORMANCE SPECIFICATIONS
- Resolution. . .8 bits
- Linearity Error. . .1/2 LSB
- Power Dissipation. . .20 mW
- Settling Time. . .100 ns
- Propagation Delay Time. . .80 ns
All trademarks are the property of their respective owners.
The TLC7628C is a dual, 8-bit, digital-to-analog converter (DAC) designed with separate on-chip data latches and featuring exceptionally close DAC-to-DAC matching. Data are transferred to either of the two DAC data latches through a common, 8-bit input port. Control input DACA/DACB determines which DAC is loaded. The load cycle of this device is similar to the write cycle of a random-access memory, allowing easy interface to most popular microprocessor buses and output ports. Segmenting the high-order bits minimizes glitches during changes in the most significant bits, where glitch impulse is typically the strongest.
The TLC7628C operates from a 10.8-V to 15.75-V power supply and is TTL-compatible over this range. 2- or 4-quadrant multiplying makes these devices a sound choice for many microprocessor-controlled gain-setting and signal-control applications.
The TLC7628C is characterized for operation from 0°C to 70°C.
