| Resolution (Bits) | 8 |
| Number of DAC channels (#) | 1 |
| Interface type | Parallel CMOS |
| Sample/update rate (MSPS) | 30 |
| Features | Low Power |
| Rating | Catalog |
| Interpolation | 1x |
| Power consumption (Typ) (mW) | 80 |
| Architecture | I-Steering |
| Operating temperature range (C) | 0 to 70 |
| Reference type | Ext |
- 8-Bit Resolution
- ±0.2% Linearity
- Maximum Conversion Rate
???????30 MHz Typ
???????20 MHz Min - Analog Output Voltage Range
????VDD to VDD –1 V - TTL Digital Input Voltage
- 5-V Single Power-Supply Operation
- Low Power Consumption . . . 80 mW Typ
- Interchangeable With Fujitsu MB40778
LinEPIC is a trademark of Texas Instruments Incorporated.
The TLC5602x devices are low-power, ultra-high-speed video, digital-to-analog converters that use the LinEPIC? 1-um CMOS process. The TLC5602x converts digital signals to analog signals at a sampling rate of dc to 20 MHz. Because of high-speed operation, the TLC5602x devices are suitable for digital video applications such as digital television, video processing with a computer, and radar-signal processing.
The TLC5602C is characterized for operation from 0°C to 70°C. The TLC5602M is characterized over the full military temperature range of ?55°C to 125°C.
