公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  190粉丝
--- 产品详情 ---
DLP? 0.65 WXGA DMD
Component type DMD
Display resolution (Max) WXGA (1280x800)
Chipset family DLP650LE, DLPC4422, DLPA100, DLPA200
Array diagonal (in) 0.65
Input frame rate (Max) (Hz) 120
  • 0.65-Inch Diagonal Micromirror Array
    • WXGA (1280 × 800) Array with >1 Million Micromirrors
    • 10.8 μm Micromirror Pitch
    • ±12° Micromirror Tilt Angle (Relative to Flat State)
    • Designed for Corner Illumination
  • 2 × LVDS Input Data Bus
  • Dedicated DLPC4422 Display Controller and DLPA100 Power Management Device and Motor Driver for Reliable Operation
  • DLPA200 Micromirror Driver
The TI DLP650LE digital micromirror device (DMD) is a digitally controlled micro-electro-mechanical system (MEMS) spatial light modulator (SLM) that enables bright, affordable WXGA display solutions. The DLP650LE DMD, together with the DLPC4422 display controller, DLPA100 power and motor driver, and DLPA200 micromirror driver comprise the DLP? 0.65” WXGA chipset. This chipset is a great solution for display systems that require WXGA resolution, high brightness, and system simplicity.
