公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
DLP? 0.65 1080p DMD
Component type DMD
Display resolution (Max) 1080p (1920x1080)
Chipset family DLP650NE, DLPC4422, DLPA100
Array diagonal (in) 0.65
Input frame rate (Max) (Hz) 120
  • 0.65-Inch Micromirror Array Diagonal
    • 1080p (1920 x 1080)
    • 7.56 Micron Micromirror Pitch
    • ± 12° Micromirror Tilt Angle (Relative to Flat State)
    • Corner Illumination
  • 2x LVDS Input Data Bus
  • Dedicated DLPC4422 Display Controller, DLPA100 Power Management IC and Motor Driver for reliable operation
The TI DLP650NE digital micromirror device (DMD) is a digitally controlled micro-opto-electromechanical system (MEMS) spatial light light modulator (SLM) that enables bright, affordable DLP? 0.65 1080p display solutions. The DLP650NE DMD, together with the DLPC4422 display controller and DLPA100 power and motor driver, comprise the DLP 0.65 1080p chipset. The solution is a great fit for display systems that require high resolution, high brightness and system simplicity.
