公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
采用 0.5mm 间距、0.64mm2 SON 封装的四路 4.8pF、±5.5V、±15kV ESD 保护二极管
Number of channels (#) 4
IO capacitance (Typ) (pF) 4.8
Vrwm (V) 5.5
IEC 61000-4-2 contact (+/- kV) 15
IEC 61000-4-5 (A) 3
Bi-/uni-directional Bi-Directional
Dynamic resistance (Typ) (?) 0.45
Clamping voltage (V) 10
IO leakage current (Max) (nA) 100
Rating Catalog
Operating temperature range (C) -40 to 125
  • Provides System Level ESD Protection for Low-voltage IO Interface
  • IEC 61000-4-2 Level 4
    • ±15kV (Air discharge)
    • ±15kV (Contact discharge)
  • IO Capacitance < 5pF
  • Ultra low Leakage Current
  • Ultra Low Clamping Voltage
  • Industrial Temperature Range: –40°C to 125°C
  • Space Saving μQFN package
The TPD4E101 is a four channel ESD protection device in an ultra small package. It is the industry’s smallest 4-ch ESD protection device. A larger pitch helps save on PCB manufacturing costs. The device provides IEC61000-4-2 compliance up to 15kV contact discharge. It has an ESD clamp circuit with back-to-back diodes for bipolar/bidirectional signal support. The low line capacitance is suitable for a wide range of applications supporting data rate up to 700Mbps.Typical application areas in portable applications are:
  • Audio lines (Microphone, Earphone and Speakerphone)
  • SD interface
  • SIM interface
  • Keypad or other buttons
