公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
适用于 USB 2.0 且具有 VCC 引脚的汽车类双路 1.5pF、5.5V、±8kV ESD 保护二极管
Number of channels (#) 2
IO capacitance (Typ) (pF) 1.5
Vrwm (V) 5.5
IEC 61000-4-2 contact (+/- kV) 8
Bi-/uni-directional Uni-Directional
Dynamic resistance (Typ) (?) 1.2
Clamping voltage (V) 25
IO leakage current (Max) (nA) +/-1
Rating Automotive
Operating temperature range (C) -40 to 85
  • Qualified for Automotive Applications
  • ESD Protection Exceeds
    • ±15-kV Human-Body Model (HBM)
    • ±8-kV IEC 61000-4-2 Contact Discharge
    • ±15-kV IEC 61000-4-2 Air-Gap Discharge
  • Low 1.5-pF Input Capacitance
  • Low 1-nA (Max) Leakage Current
  • 0.9-V to 5.5-V Supply-Voltage Range
  • Two-Channel Device
  • Space-Saving DRL Package
  • Alternate 3-, 4-, 6-Channel Options Available:
    TPD3E001, TPD4E001, and TPD6E001
  • APPLICATIONS
    • USB 2.0
    • Ethernet
    • FireWire?
    • Video
    • Cell Phones
    • SVGA Video Connections
    • Glucose Meters
FireWire is a trademark of Apple Computer, Inc.
The TPD2E001 is a low-capacitance ±15-kV ESD-protection diode array designed to protect sensitive electronics attached to communication lines. Each channel consists of a pair of diodes that steer ESD current pulses to VCC or GND. The TPD2E001 protects against ESD pulses up to ±15-kV Human-Body Model (HBM), ±8-kV Contact Discharge, and ±15-kV Air-Gap Discharge, as specified in IEC 61000-4-2. This device has a 1.5-pF capacitance per channel, making it ideal for use in high-speed data IO interfaces.
The TPD2E001 is a two-channel device intended for USB and USB 2.0 applications.
The TPD2E001 is available in the DRL package and is specified for –40°C to 85°C operation.
