公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
适用于 USB 接口且具有可耐受 15V 电压的 Vbus 的四路 0.8pF、5.5V、±8kV ESD 保护二极管
Number of channels (#) 4
IO capacitance (Typ) (pF) 0.8
Vrwm (V) 5.5
IEC 61000-4-2 contact (+/- kV) 10
IEC 61000-4-5 (A) 3
Bi-/uni-directional Uni-Directional
Dynamic resistance (Typ) (?) 1
Clamping voltage (V) 8
IO leakage current (Max) (nA) 500
Rating Catalog
Operating temperature range (C) -40 to 85
  • Integrated ESD Clamps on all Pins
  • USB Signal Pins (D+, D–, ID)
    • 0.8-pF Line Capacitance
  • Supports Data Rates in Excess of 480 Mbps
  • IEC 61000-4-2 ESD Protection (Level 4 Contact)
    • ±10-kV IEC 61000-4-2 Contact Discharge
  • IEC 61000-4-5 Surge
    • 3 Amps Peak Pulse Current
  • APPLICATIONS
    • Cellular Phones
    • Digital Cameras
    • Global Positioning Systems (GPS)
    • Portable Digital Assistants (PDA)
    • Portable Computers
All other trademarks are the property of their respective owners
The TPD4S012 is a four-channel Transient Voltage Suppressor (TVS) based Electrostatic Discharge (ESD) protection diode array for USB chargers and USB On-The-Go (OTG) interfaces.
The TPD4S012 provides IEC 61000-4-2 system level ESD Protection featuring 15 V tolerance on the VBUS line. The device is ideal for providing circuit protection for USB charger and OTG applications due to its high-voltage tolerance at the VBUS line and small flow-through package.
