公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
适用于 HDMI 和 DisplayPort 的 8 通道 0.8pF、5.5V、±8kV ESD 保护二极管
Number of channels (#) 8
IO capacitance (Typ) (pF) 0.8
Vrwm (V) 5.5
IEC 61000-4-2 contact (+/- kV) 8
IEC 61000-4-5 (A) 2.5
Bi-/uni-directional Uni-Directional
Dynamic resistance (Typ) (?) 1.1
Clamping voltage (V) 20
IO leakage current (Max) (nA) 100
Rating Catalog
Operating temperature range (C) -40 to 85
  • IEC 61000-4-2 Level 4 ESD Protection
    • ±8-kV Contact Discharge
  • IEC 61000-4-5 Surge Protection
    • 2.5 A (8 / 20 μs)
  • I/O Capacitance: 0.8 pF (Typical)
  • Low Leakage Current: 10 nA (Typical)
  • Supports High-Speed Differential Data Rates (3-dB Bandwidth > 4 GHz)
  • Ioff Feature
  • Industrial Temperature Range:–40°C to +85°C
  • Easy Straight-Through Routing Package for HDMI and DisplayPort Connectors
All trademarks are the property of their respective owners.
The TPD8S009 device is an eight-channel TVS diode array for ESD protection. The TPD8S009 is rated to dissipate contact ESD strikes at the maximum level specified in the IEC 61000-4-2 international standard (Level 4), with ±8-kV contact discharge ESD protection. The low capacitance (0.8 pF) of this device, coupled with the excellent matching between differential signal pairs enables this device to provide transient voltage suppression circuit protection for high-speed idfferential data rates (3-dB bandwidth >
4 GHz).
The TPD8S009 is offered in a 8-pin SON package. This package offers easy design and layout, as the package matches exactly with the HDMI and DisplayPort high-speed pinout.
