公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
适用于高速接口且具有 VCC 引脚的四路 0.8pF、5.5V、±8kV ESD 保护二极管
Number of channels (#) 4
IO capacitance (Typ) (pF) 1.6
Vrwm (V) 5.5
IEC 61000-4-2 contact (+/- kV) 8
Bi-/uni-directional Uni-Directional
Clamping voltage (V) 14
Rating Catalog
Operating temperature range (C) -40 to 85
  • IEC 61000-4-2 ESD Protection
    • ±8-kV IEC 61000-4-2 Contact Discharge
    • ±12-kV IEC 61000-4-2 Air-Gap Discharge
  • ANSI/ESDA/JEDEC JS-001
    • ±15-kV Human Body Model (HBM)
  • Low 1.6-pF Input Capacitance
  • 0.9-V to 5.5-V Supply Voltage Range
  • 4-Channel Device
  • Space-Saving SON (DRY) Package
The TPD4E004 is a low-capacitance transient voltage suppression (TVS) device. TPD4E004 is designed to protect sensitive electronics attached to communication lines from electrostatic discharge (ESD). Each of the four channels consists of a pair of diodes that steer ESD current pulses to VCC or GND. The TPD4E004 protects against ESD pulses up to ±15-kV Human-Body Model (HBM) and, as specified in IEC 61000-4-2, ±8-kV contact discharge and ±12-kV air-gap Discharge. This device has 1.6-pF of capacitance per channel, making it ideal for use in high-speed data IO interfaces.
The TPD4E004 is a quad-ESD structure designed for USB, ethernet, and other high-speed applications.
