公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
适用于高速接口的 6 通道、1.6pF、5.5V、8kV ESD 保护二极管
Number of channels (#) 6
IO capacitance (Typ) (pF) 1.6
Vrwm (V) 5.5
IEC 61000-4-2 contact (+/- kV) 8
Bi-/uni-directional Uni-Directional
Clamping voltage (V) 20
Rating Catalog
Operating temperature range (C) -40 to 85
  • ESD Protection Exceeds JESD
    • ±15-kV Human-Body Model (HBM)
    • ±8-kV IEC 61000-4-2 Contact Discharge
    • ±12-kV IEC 61000-4-2 Air-Gap Discharge
  • Low 1.6-pF I/O Capacitance
  • 0.9-V to 5.5-V Supply-Voltage Range
  • 6-Channel Device
  • Space-Saving UQFN (RSE) Package
The TPD6E004 device is a low-capacitance, ±15-kV ESD-protection diode array designed to protect sensitive electronics attached to communication lines. Each channel consists of a pair of diodes that steers ESD current pulses to VCC or GND. The TPD6E004 protects against ESD pulses up to ±15-kV human-body model (HBM), ±8-kV contact ESD, and ±12-kV air-gap ESD as specified in IEC 61000-4-2. This device has a typical 1.6-pF capacitance per channel, making it ideal for use in high-speed data I/O interfaces.
The TPD6E004 device is available in the RSE package and is specified for ?40°C to +85°C operation.
The TPD6E004 device is a six-channel ESD structure designed for USB, Ethernet, and FireWire applications.
